Bundera leaning to the right
Jordan
I am hopping someone will direct me on why is my 1988 Bundera/landcruiser II (coils all arount) wants to lean to the left no matter what I do……
My car was leaning to the left so I ordered and installed a set of new TJM coils front and back but its still leaning to the left. There is a 1.5 cm difference between left and right side measuring from the front and 1cm difference between left to right back.
It has a rancho rs9000 shocks but I had to modify the left rear shock mount to fit a longer shock so now I have the same size shocks on both sides. but the left one is mounted leaning more then the right one.
Did you get the drivers side spring on the correct side?
Otherwise try swapping springs from L to R or get them reset
Great your from Australia .... each coil is labeled RH and LH so I installed the LH (driverside) and RH (passanger side) but australian cars are right hand drive.. do you think the coils are made for right hand drive cars....since TJM is australian company
This has long been a subject of debate and I dont know the answer. Some springs are labelled A and B with A going on the drivers side.
You would think TJM would have recognised that their springs are destined for LHD markets and stamped them accordingly.
I would contact the dealer you got them from.
With my leaf springs I turned them upside down and put the highest one on the drivers side.
At least its fixed
Check this out.......... I removed the coils and guess what ....the one labeled R/F is actually longer than the one labeled L/F so I switched them and the rears .Now the car is standing level like it should be............ So i guess the kit is made for right hand drive and not left ones like mine......
So thanks Man
So thanks Man
Good result;)
