Bump Stop Options for Front Suspension (1 Viewer)
Albany, Oregon
My passenger side bump stop is missing massive chunks and doesn’t look like it will do much of anything anymore.
Are there options out there to replace these for a reasonable price? Found some OEM ones but they are almost $60 a piece.
Should I look at larger ones since I did a 2” OME lift?
If so any recommendations for bolt on options?
What hits first at full compression on the good side? Shock bottoming, tire to fender, or bump stop?
Not sure what would hit. Just saw the passenger side was all tore up and was thinking of repairing it.
The reason I ask is that with a non stock setup of tires and suspension, if you replace with stock bump stop , it may not do anything to prevent bottoming out your shocks.
Do OME lifts come with new bumpstops?
The kit I bought did not. I had to buy new sway bar links separate as well.
Taller springs require lengthened bump stops if you don’t want to break your shock mounts.
The OEM bump stop is easy to lengthen. Just put an aluminum block between it and the frame
