Jacket
Moderator
Posting this in the 100 series forum since I think more of you guys have his rear bumper and tire carrier. Mike (from BIOR) and I have talked back and forth about this issue, but it's not an "easy fix" as far as we can determine and I'm wondering if others might have a similar issue and possibly a fix that works.
What I have: BIOR high clearance rear bumper with tire carrier mounted on passenger side. Install has the standard latch with a welded catch on the outboard side, and a spring pin mounted inboard close to the spindle.
My problem: No matter how I adjust the latch, after I drive the truck for a few miles the tire carrier is "wandering" outward away from the truck and is causing the latch to effectively tighten and lock itself into place. It takes two hands a lot of body weight to heave the latch open. The spring pin should prevent this arm movement in theory, but for some reason it is not. There is about 1/4" of play in the spring pin, and I've tried adjusting the latch so that when I close the tire carrier the pin is effectively resting against the outer lip of the bumper hole where the pin secures into. But sure enough as soon as I drive it the latch wanders outward and tightens itself.
Anyone else having issues like this?
