Ever since I sold my '02 LX I've been mourning the loss. Then I found satsifaction with an '04 LS430 but still wanted a truck to relieve the urge for a vehicle that gives that whiff of 'I could take this anywhere'. I remember reading, somewhere on these here forums, some guy saying 'we think our truck's got looks, when everyone else thinks it's a frumpy soccermom SUV'. Pretty accurate - but I still think they're dang good lookin.
Anyway I found a VVTI truck after 3-4 months of searching. Had to fly clear across the state to get it, and the story was the guy bought it (sight unseen from a dealer) for his wife but she had been spoiled by all the tech in an X5 and wasn't interested. Turns out he had had an LX before, too. Two-owner Texas truck before the guy bought it, and he hadn't yet registered it in California, so officially I'm the third owner, and he had rear brakes and timing belt done on it in the two months that he owned it. Great service record, pieced together from the Lexus website and carfax.
The only problem I could see from afar was the awful gold package decals. I bought a rubber wheel before I bought the truck. Found out when I got there that there was an RMS leak, and the AHC felt rock hard. By then I was committed and I drove it tag-less to my folks place in the high desert.
Drove it home, following a 570 most of the way out of Tehachapi.
Gross, right? No thanks!
First order of business: getting those decals off. Tried a couple solvents before I realized just a grey scotch brite pad was all it took.
More brushed nickel than chrome, but I'll take it. Also futzed around with decal placement and settled on this:
Also scored a brand new 1up rack for 400 off craigslist around the same time.
Previous owner cared enough about it to reupholster. i'm pretty partial to 'saddle' interiors and maybe this is more orange than saddle but I liked it right away.
Edit: putting the history in here so I can look it up easier:
Lexus driver's website:
6/22/2017 (109227 miles)
REPAIR NUMBER: 0803152
REPORTED BY: Westside Lexus
SERVICE: WORLD CLASS INSPT'S
DESCRIPTION: ~|~WORLD CLASS INSPECTION - PLEASE FIND AND REVIEW ATTACHED VEHICLE INSPECTION REPORT ~|~ATTACHED INSPECTION REPORT CONTAINS IMPORTANT INFORMATION ABOUT YOUR VEHICLE. ~|~FOR YOUR CONVENIENCE WE HAVE REGISTERED YOUR VEHICLE IN OUR AUTOMATED RECOGNITION SYSTEM. THIS WILL ALLOW US TO INSTANTLY IDENTIFY YOUR VEHICLE WHEN YOU ARRIVE IN THE SERVICE DEPT SO THAT WE MAY SERVE YOU MORE EFFICIENTLY. A DISCREET TAG HAS BEEN APPLIED
SERVICE: GENERATOR/STARTER/MTR-GAUGE
DESCRIPTION: ~|~CUSTOMER STATES THAT BATTERY LIGHT ON ~|~FOUND ALTERNATOR FAILED LOAD TEST - RECOMMEND TO REPLACE NEW ALTERNATOR ~|~ALTERNATOR, R&R 05/07 - COMPLETED
SERVICE: DECLINED RECOM SVC
DESCRIPTION: ~|~DECLINED RECOMMENDED SERVICE ~|~FOUND AFTERMARKET BATTERY FAILED LOAD TEST - RECOMMEND TO REPLACE NEW OEM BATTERY ~|~CUSTOMER DECLINED TO REPLACE NEW OEM BATTERY - CUSTOMER WILL TAKE VEHICLE TO AFTERMARKET BATTERY SHOP. NO WORK PERFORMED AT THIS TIME
6/21/2017 (109226 miles)
REPAIR NUMBER: 0803080
SERVICE: INSPECT AUTO TRANS & DIFFERENTIAL
DESCRIPTION: ~|~CUSTOMER STATES THAT VEHICLE MAKES HUMMING/WHINING SOUND WHEN IDLING ~|~FOUND TORQUE CONVERTER MAKING WHINING SOUND AND REAR MAIN ENGINE SEAL SEEPING - RECOMMEND TO REPLACE NEW TRANSMISSION AND RESEAL REAR MAIN ENGINE SEAL ~|~CUSTOMER DECLINED TO REPLACE NEW TRANSMISSION AND RESEAL REAR MAIN ENGINE SEAL - NO WORK PERFORMED AT THIS TIME
2/22/2017 (108103 miles)
REPAIR NUMBER: 0775438
SERVICE: DECLINED MAINT SVC
DESCRIPTION: ~|~DECLINED MAINTENANCE SERVICE ~|~FOUND VEHICLE PAST DUE FOR 105,000 MILE SERVICE - RECOMMEND TO PERFORM A 105,000 MILE SERVICE ~|~CUSTOMER DECLINED 105,000 MILE SERVICE - NO WORK PERFORMED AT THIS TIME
SERVICE: CURTAIN AIRBAG GX/LX
DESCRIPTION: ~|~SAFETY RECALL GLB. CERTAIN 2004-2006 GX470 AND 2003-2006 LX470 VEHICLES CURTAIN-SHIELD AIRBAG CONTROL MODULE. ~|~THE SUBJECT VEHICLES ARE EQUIPPED WITH SIDE CURTAIN-SHIELD AIRBAGS WHICH DEPLOY FROM THE ROOF RAILS IN THE EVENT OF CERTAIN TYPES OF CRASHES. DUE TO IMPROPER PROGRAMING IN THE AIRBAG CONTROL MODULE, THERE IS A POSSIBILITY THAT, UNDER CERTAIN SPECIFIC AND ~|~AN AUTHORIZED LEXUS DEALER WILL REPLACE THE AIRBAG CONTROL MODULE AT NO CHARGE - COMPLETED OP CODE CGG01C 2.1 HOURS WARRANTY
DESCRIPTION:
3/24/2015 (97072 miles)
REPAIR NUMBER: 0628486
SERVICE: FRONT WHEEL ALIGNMENT
DESCRIPTION: ~|~REQUESTED FOUR WHEEL ALIGNMENT ~|~REPLACED NEW STEERING RACK AND FRONT DRIVE AXLE BOOTS - SEE LINE 3 AND LINE 4 ~|~ALIGN FOUR WHEELS - COMPLETED
SERVICE: *AXLE DIAGNOSIS
DESCRIPTION: ~|~CUSTOMER REQUEST TO INSPECT CV BOOTS FOR LEAKS ~|~FOUND BOTH FRONT INNER AND OUTER C.V. BOOTS TORN AND LEAKING - RECOMMEND TO REPLACE BOTH NEW FRONT DRIVE AXLE CV BOOTS ~|~REPLACED BOTH NEW FRONT DRIVE AXLE C.V. BOOT KITS - COMPLETED LEXUS EXTRA CARE (800) 448-1505 [NICK] AUTHORIZATION #VSA3BW6883
SERVICE: STEERING WHL/MAIN SHAFT
DESCRIPTION: ~|~UPON INSPECTION - FOUND POWER STEERING RACK AND PINION LEAKING ~|~FOUND RACK AND PINION LEAKING FROM BOTH BELLOWS BOOTS. ~|~REPLACED POWER RACK AND PINION ASSEMBLY - COMPLETED LEXUS EXTRA CARE (800) 448-1505 [NICK] AUTHORIZATION #VSA3BW6883
SERVICE: WATER PUMP
DESCRIPTION: ~|~UPON INSPECTION - FOUND WATER PUMP LEAKING ~|~FOUND WATER PUMP LEAKING - RECOMMEND TO REPLACE NEW WATER PUMP ~|~REPLACED NEW WATER PUMP ASSEMBLY AND TOPPED OFF COOLANT - COMPLETED LEXUS EXTRA CARE (800) 448-1505 [NICK] AUTHORIZATION #VSA3BW6883
12/21/2012 (80874 miles)
REPAIR NUMBER: 0463200
SERVICE: OTHER NON-OEM ACCESSORY INSTALL/R&R
DESCRIPTION: ~|~INSTALL DVD CHANGER ~|~REPLACE CENTER CONSOLE N FRONT 2 SEATS ~|~INSTALL DVD CHANGER
10/22/2012 (80874 miles)
REPAIR NUMBER: 0460886
SERVICE: INSPECT BRAKE PADS & DISKS
DESCRIPTION: ~|~REPLACE FRONT BRAKE PADS RESURFACE FRONT BRAKE ROTORS ~|~COMPLETE E ~|~FRONT BRAKE JOB, INCLS. REFACING, W/O HARDWARE, R&R 03/07
SERVICE: *REAR BRAKE PADS
DESCRIPTION: ~|~REPLACE REAR BRAKE PADS RESURFACE REAR BRAKE ROTORS ~|~COMPLETE E ~|~REAR BRAKE JOB, INCLS. REFACING, W/O HARDWARE, R&R 98/07
10/21/2012 (80178 miles)
REPAIR NUMBER: 0460304
SERVICE: BATTERY
DESCRIPTION: ~|~C/S VEHICLE HARD STARTING/ REQUIRES JUMPSTART ~|~COMPLETE E ~|~BATTERY, R&R 98/07 US
DESCRIPTION: ~|~REQUESTED FOUR WHEEL ALIGNMENT ~|~COMPLETE ~|~ALIGN FOUR WHEELS ALL
SERVICE: 30000 MILE SERVICE NON WARRANTY
DESCRIPTION: ~|~CUSTOMER REQUESTS A 90K MILE SERVICE ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~90K MILES OR 108 MONTHS
9/11/2012 (79651 miles)
REPAIR NUMBER: 0452633
SERVICE: STATE INSPECTION
DESCRIPTION: ~|~CUSTOMER REQUESTS 1 YEAR STATE INSPECTION VIR ~|~STATE REGULATIONS ~|~1 YEAR STATE INSPECTION ALL
2/27/2012 (73375 miles)
REPAIR NUMBER: 0981241
DESCRIPTION: ~|~WORLD CLASS INSPECTION ~|~ ~|~COMPLETED W/ SERVICE FRONT AND REAR BRAKES AT 4MM, MAY NEED NEXT SERVICE. ALL ARE OK AT THIS TIME.
SERVICE: 65000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: ~|~CUSTOMER REQUESTS A 65K MILE SERVICE ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE 34PSI 8/32 TIRES 4MM FT & R BRKS ~|~65K MILES OR 78 MONTHS 5529/6388
8/25/2011 (67697 miles)
REPAIR NUMBER: 0946978
DESCRIPTION: ~|~CUSTOMER REQUESTS A 60K MILE SERVICE ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~60K MILES OR 72 MONTHS
SERVICE: *FUEL INJT FLUSH W/S
DESCRIPTION: ~|~FUEL SYSTEM TUNE UP WITH SERVICE ~|~PREVENTATIVE MAINTENANCE RECOMMENDED BY TIME AND MILEAGE ~|~PERFORMED COMPLETE FUEL SYSTEM CLEAN & FLUSH TUNE UP. FLUSHED FUEL INJECTORS & FUEL LINES, CLEANED THROTTLE BODY ASSY, AND DECARBED ALL TOP ENGINE VALVES
SERVICE: ST/SHAFT SNAP RING
DESCRIPTION: ~|~SAFETY RECALL ALF ~|~LX470 STEERING SHAFT SNAP RING ~|~INSTALL NEW SNAP RING / OP 0523G1
2/18/2011 (61632 miles)
REPAIR NUMBER: 0911884
SERVICE: 55000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: ~|~CUSTOMER REQUESTS A 55K MILE SERVICE ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~55K MILES OR 66 MONTHS
DESCRIPTION: ~|~WORLD CLASS INSPECTION ~|~ ~|~COMPLETE W/ SERVICE
SERVICE: MISC
DESCRIPTION: ~|~C/S RADAR DETECTOR NOT WORKING. CHECK FOR ON/OFF SWITCH NOTICED AFTER LEAVING FROM LAST VISIT ~|~REMOTE FOR K40 HAD TO AAAA BATTERIES ENERGIZER BRAND ~|~REPLACED BATTERIES W/ DURACELL BRAND BATTERIES, SYSTEM WORKS FINE NOW. ADVISE CUSTOMER IF REPLACING THE BATTERIES THEM SELFS, TO DO W/ DURACELL ONLY BATTERIES
7/28/2010 (56466 miles)
REPAIR NUMBER: 0873314
SERVICE: 50000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: ~|~CUSTOMER REQUESTS A 50K MILE SERVICE ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~50K MILES OR 60 MONTHS 34PSI 5-6/32 5-6MM FT & R BRKS
DESCRIPTION: ~|~WORLD CLASS INSPECTION ~|~ ~|~COMPLETED W/SERVICE
12/27/2009 (50981 miles)
REPAIR NUMBER: 0831972
SERVICE: 40000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: ~|~CUSTOMER REQUEST A 45K MILE SERVICE ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~45K MILES OR 54 MONTHS
DESCRIPTION: ~|~WORLD CLASS INSPECTION ~|~REC FUEL INJECTION FLUSH NEXT VISIT ~|~COMPLETED W/SERVICE
SERVICE: LOW TIRE INDICATOR
DESCRIPTION: ~|~C/S LOW TIRE WARNING LAMP IS ON ~|~SPARE TIRE AT 27 PSI ~|~SET TIRES TO 34 PSI
7/8/2009 (45681 miles)
REPAIR NUMBER: 0799433
DESCRIPTION: ~|~LEFT BUTTONS OF STEERING WHEEL HAS PIECE THAT FELL OFF AND WAS LOST. INSTALL SOP PART. ~|~BROKEN OFF, NO PARTS, NOT WARRANTY ~|~INSTALLED LEFTSIDE STEERING WHEEL BUTTON SWITCH
DESCRIPTION: ~|~CUSTOMER REQUESTS A 40K MILE SERVICE CK EXT LIGHTS, BODY, & CHASIS ROAD TEST VEHICLE. CHECK TIRE PRESSURE AND ROTATE TIRES UNLESS OTHERWISE SPECIFIED INSPECT AND CLEAN BATTERY TERMINALS. INSPECT ENGINE AIR FILTER INSPECT BRAKE FLUID LEVEL ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~PERFORMED 40K MILES OR 48 MONTHS SERVICE AT 45,000MI
SERVICE: LOANER CAR
DESCRIPTION: ~|~LOANER ~|~IN ORDER TO PROVIDE EXCELLENT SERVICE TO OUR CUSTOMERS, PLEASE RETURN YOUR LOANER CAR WITHIN 12 BUSINESS HOURS UPON NOTIFICATION OF YOUR VEHICLE BEING READY. ~|~SURCHARGE FOR LOANER VEHICLE
3/17/2009 (40204 miles)
REPAIR NUMBER: 0778281
SERVICE: 35000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: ~|~CUSTOMER REQUESTS A 35K MILE SERVICE CK EXT LIGHTS, BODY, & CHASIS ROAD TEST VEHICLE. CHECK TIRE PRESSURE AND ROTATE TIRES UNLESS OTHERWISE SPECIFIED INSPECT AND CLEAN BATTERY TERMINALS. INSPECT ENGINE AIR FILTER INSPECT BRAKE FLUID LEVEL ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~35K MILES OR 42 MONTHS AT 35
SERVICE: LOANER CAR
DESCRIPTION: ~|~LOANER ~|~ ~|~SURCHARGE FOR LOANER VEHICLE
DESCRIPTION: ~|~CUSTOMER REQUESTS 1 YEAR STATE INSPECTION EXPD 2/9, INS IN GLOVE BOX ~|~STATE REGULATIONS ~|~1 YEAR STATE INSPECTION ALL
DESCRIPTION: ~|~C/S THERE IS A BUTTON THAT FELL OFF OF STEERING WHEEL. ~|~ ~|~CUSTOMER ADVISED NOT A WARRANTY MATTER W/OUT MISSING BUTTON TO TURN IN. SEE ESTIMATE FOR REPLACMENT OF LEFT BUTTON SWITCH FOR STEERING WHEEL.
SERVICE: WINDSHIELD WIPER/WASHER
DESCRIPTION: ~|~C/S REAR WIPER IS MAKING NOISE, SCREECHING,. PLEASE INSPECT. ALSO INSPECT FRONT. ~|~ ~|~REPLACED ALL THREE WIPER BLADE INSERTS
10/2/2008 (34648 miles)
REPAIR NUMBER: 0747684
DESCRIPTION: ~|~CUSTOMER REQUESTS A 30K MILE SERVICE ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~30K MILES OR 36 MONTHS AT 30 TIRES AT 7/32'S BRAKES AT 7MM
DESCRIPTION: ~|~C/S LOW TIRE WARNING LAMP IS ON ~|~SPARE TIRE LOW 26 PSI,ALSO R/FRONT TIRE HAD A NAIL ~|~SET TIRE PRESSURE TO 34PSI AND REPAIR TIRE
DESCRIPTION: ~|~PLEASE INSTALL A NEW TRAILER HITCH COVER. ~|~ ~|~INSTALLED TRAILER HITCH COVER. N/C
SERVICE: CP CARWASH
DESCRIPTION: ~|~COMPLIMENTARY CAR WASH
8/6/2008 (31884 miles)
REPAIR NUMBER: 0736742
SERVICE: NON WARRANTABLE OPERATION CODE
DESCRIPTION: ~|~REPAIR AS PER ESTIMATE!! HOLD FOR INSURANCE ~|~BODY DAMAGE ~|~SEE ESTIMATE FOR DETAILS
5/7/2008 (29163 miles)
REPAIR NUMBER: 0720804
DESCRIPTION: ~|~PLEASE RESET MAINT REQ'D LAMP ~|~ ~|~DONE
SERVICE: CP CARWASH
DESCRIPTION: ~|~COMPLIMENTARY CAR WASH ~|~ ~|~DONE
SERVICE: 25000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: ~|~CUSTOMER REQUESTS A 25,000 MILE SERVICE CK EXT LIGHTS, BODY, & CHASIS ROAD TEST VEHICLE. CHECK TIRE PRESSURE AND ROTATE TIRES UNLESS OTHERWISE SPECIFIED INSPECT AND CLEAN BATTERY TERMINALS. INSPECT ENGINE AIR FILTER INSPECT BRAKE FLUID LEVEL ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~25K MILES OR 30 MONTHS AT 25 BRAKES 8MM IN FRONT, 9MM IN REAR. ALL TIRES AT 8/32NDS SEE REPORT CARD IF NEED. VEHICLE DUE FOR MAJOR 30K SERVICE NEXT VISIT.
2/21/2008 (26359 miles)
REPAIR NUMBER: 0706682
DESCRIPTION: ~|~CUSTOMER REQUESTS 1 YEAR STATE INSPECTION EXPS 2-8 ~|~STATE REGULATIONS ~|~1 YEAR STATE INSPECTION ALL
SERVICE: RADIO/CD PLAYER
DESCRIPTION: ~|~C/S DVD PLAYER DOESNT EJECT OR INSERT. CK. ~|~ ~|~ORDERED DVD/CD CHANGER ASSY
SERVICE: FRONT/REAR BODY
DESCRIPTION: ~|~C/S REAR TOW HITCH COVER FELL OFF DURING LAST WASH. PLEASE REPLACE. ~|~ ~|~MAKE READY TO INSTALL
SERVICE: NON-OEM RADAR DECTOR INSTALL/R&R
DESCRIPTION: ~|~C/S THE REMOTE CONTROL FOR RADAR SYSTEM HAS FALLEN OFF AND MISPLACED PLEASE CK W/ PARTS FOR REPLACEMENT. ~|~ ~|~REPLACED REMOTE. CUSTOMER GIVEN AT SERVICE DESK.
DESCRIPTION: ~|~C/S CENTER ASHTRAY COVER FELL OFF AND NEEDS TO BE SECURED. ~|~FT ASHTRAY ASSY STICKING AND CLOVER FELL OFF OF TRAY ASSY ~|~REPLACED ASH TRAY ASSY AND CLEANED DEBRIS LOCATED IN ASSY OP# 550991 0.2HRS T1-62 T2-83
12/18/2007 (23364 miles)
REPAIR NUMBER: 0694654
DESCRIPTION: ~|~PLEASE RESET MAINT REQ'D LAMP ~|~ ~|~COMPLETED.
SERVICE: AIR CONDITIONING
DESCRIPTION: ~|~C/S ONCE HEAT WAS ON, TOOK FOREVER TO COOL DOWN. PLEASE TEST ALL OPERATIONS TO DETERMINE IF ALL IS OK. ~|~ ~|~THE A/C SYSTEM IS OPERATING AS DESIGNED.
SERVICE: NAVIGATION COMPUTER
DESCRIPTION: ~|~CUSTOMER HAD SOME QUESTIONS ON NAVIGATION USE, PLEASE SEE IF PARTS HAS C/D OR DVD INSTRUCTIONAL. ~|~ ~|~PLACED THE INSTRUCTIONAL DVD FOR THE NAVIGATION SYSTEM ON THE FRONT PASSENGER'S SEAT.
DESCRIPTION: ~|~C/R TO REPLACE ALL WIPER INSERTS, FRONT AND BACK. ~|~ ~|~REPLACED ALL THREE WIPER REFILLS.
SERVICE: 20000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: ~|~CUSTOMER REQUESTS A 20,000 MILE SERVICE CK EXT LIGHTS, BODY, & CHASIS ROAD TEST VEHICLE. CHECK TIRE PRESSURE AND ROTATE TIRES UNLESS OTHERWISE SPECIFIED INSPECT AND CLEAN BATTERY TERMINALS. INSPECT ENGINE AIR FILTER INSPECT BRAKE FLUID LEVEL ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~PERFORMED 20K SERVICE. FRONT & REAR BRAKES ARE AT 8MM. ALL TIRES ARE AT 8/32.
7/24/2007 (18196 miles)
REPAIR NUMBER: 0664944
DESCRIPTION: ~|~REPAIR PER ESTIMATE ~|~ ~|~REPAIRED PER ESTIMATE
7/11/2007 (17500 miles)
REPAIR NUMBER: 0664723
DESCRIPTION: ~|~PLEASE GET B/S EST ON REAR BUMPER DAMAGE L/R. ~|~SENT TO BODY SHOP. ~|~ESTIMATE IS ON FRONT SEAT.
SERVICE: MISC MAINT
DESCRIPTION: ~|~NO CAR WASH, DRIVE UP AS SOON AS FINISHED. ~|~ ~|~DONE
SERVICE: 10000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: ~|~ ~|~ ~|~15K MILES OR 18 MONTHS 36PSI 10/32 9MM 8MM
1/8/2007 (11267 miles)
REPAIR NUMBER: 0632416
DESCRIPTION: ~|~C/S K-BAN RADAR NOT WORKING PROPERLY ~|~ ~|~REPLACE BATTERY IN RADAR
SERVICE: CP CARWASH
DESCRIPTION: ~|~COMPLIMENTARY CAR WASH ~|~ ~|~OK
DESCRIPTION: ~|~RESET MAINT REQ LT ~|~ ~|~OK
SERVICE: OTHERS
DESCRIPTION: ~|~C/S WHEN FIRST ACCELERATING THERE IS A VERY FAINT HUMMING NOISE HEARD FROM DASH ~|~ ~|~NO ABNORMAL HUMMING NOISE HEARD ON ACCELERATING
DESCRIPTION: ~|~CHANGE ENGINE OIL AND FILTER. CHECK ALL FLUIDS CK PADS, ROTORS, LINES, HOSES, CALIPERS, & PARKING BRAKE. CK STEERING GEAR & LINKAGE, BALL JOINTS AND DUST COVERS. CK EXT LIGHTS, BODY, & CHASIS ROAD TEST VEHICLE. CHECK TIRE PRESSURE AND ROTATE TIRES UNLESS ~|~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~|~10K MILES OR 12 MONTHS
6/20/2006 (5310 miles)
REPAIR NUMBER: 0598463
SERVICE: CP CARWASH
DESCRIPTION: ~|~COMPLIMENTARY CAR WASH ~|~ ~|~OPK
SERVICE: 5,000 MILE SERVICE
DESCRIPTION: ~|~CHANGE ENGINE OIL AND FILTER. CHECK ALL FLUIDS CK PADS, ROTORS, LINES, HOSES, CALIPERS, & PARKING BRAKE. CK STEERING GEAR & LINKAGE, BALL JOINTS AND DUST COVERS. CK EXT LIGHTS, BODY, & CHASIS ROAD TEST VEHICLE. CHECK TIRE PRESSURE AND ROTATE TIRES UNLESS ~|~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~|~5,000 MILE SERVICE PERFORMED
SERVICE: 1,000 MILE SERVICE
DESCRIPTION: ~|~LEXUS PERSONALIZED SETTINGS PROGRAM INSPECT AIR PRESSURE IN TIRES. ROAD TEST VEHICLE. ~|~ ~|~CHANGED SETTING PER CUSTOMER REQUEST ON SELECTION FORMS OP CODE 001030 .4
1/22/2006 (12 miles)
REPAIR NUMBER: 0156026
REPORTED BY: Lexus of Birmingham
SERVICE: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
DESCRIPTION: ~|~PRE-DELIVERY INSPECTION ~|~ ~|~COMPLETED PRE-DELIVERY INSPECTION.
DESCRIPTION: ~|~INSTALL VEHICLE TAG & BOLT KIT. ~|~ ~|~INSTALLED VEHICLE TAG & BOLT KIT.
1/19/2006 (1 miles)
REPAIR NUMBER: 0156109
SERVICE: DETAIL
DESCRIPTION: ~|~DETAIL VEHICLE
