Build Build: 1994 Project - "Spring"
Well crew - I had the opportunity to pull the trigger on a new OEM short block and have a shop that is open and willing to help put it in so this is happening. It is time to finally call this a build thread.
After spending the past few months scanning the threads of other builds, the following is the initial parts list I am going in with:
NameQtyPart #
BLOCK ASSEMBLY, SHORT
1​
1140066041
GASKET KIT ENGINE
1​
04111-66036
TENSIONER ASSY, CHAIN, NO.1
1​
13540-66011
Gasket chain tension
1​
13552-66010
Head bolts
14​
90910-02111
Head bolt washers
14​
90201-12222
Front engine mount
2​
12361-17011
Rear Mount (aka Trans mount)
1​
12371-66030
GASKET, OIL COOLER
2​
15785-66010
BOLT, STUD(FOR MANIFOLD TO CYLINDER HEAD)
4​
90080-12007
Possible STUD(FOR MANIFOLD TO CYLINDER HEAD)
4​
90126-08008
NUT, LOCK
4​
90080-17187
NUT, LOCK- FOR MANIFOLD TO HEAD
13​
90179-10128
BOLT, STUD(FOR EXHAUST MANIFOLD TO CYLINDER HEAD)
13​
90116-10169
Valve cover gasket
1​
11213-66021
Throttle body gasket
1​
22271-66010
Spark plug tube seals
6​
11193-15010
PCValve Grommet
1​
90480-18001
Fuel Filter Assembly
1​
23300-69045
103 FIPG
1​
Engine Oil Pressure Switch (sender unit)
1​
83520-60011
Alignment - 11434H Front near tining cover
2​
90253-11021
Alignment - 11434X bottom right
2​
90253-13002
Alignment - 11434C Rear top
2​
90253-15007
Alignment - 11434D Rear by trans
1​
90250-06068
Alignment - 11434B Rean by trans
2​
90250-08054
ROTOR SET, OIL PUMP
1​
15102-66020
Updated Block Drain
1​
90910-09129
Timing Chain
1​
13506-66010
Timing Chain vibration damper NO.1
1​
13561-66010
Timing Chain Tensioner Slipper
1​
13559-66011
Timing chain gear or sprocket, camshaft timing
1​
13523-66020
Camshaft sub gear
1​
13529-62901
Gear or Sprocket, Crankshaft timing
1​
13521-66020
Engine Water Pump
1​
16100-69325
Radiator
1​
16400-66040
HOSE, RADIATOR, NO.1
1​
16571-66030
HOSE, RADIATOR, NO.2
1​
16572-66021
HOSE, RADIATOR, NO.3
1​
16573-66010
Thermostat
1​
90916-03117
HOSE, HEATER WATER, INLET B
1​
87245-60480
HOSE, HEATER WATER, OUTLET A
1​
87245-60350
HOSE, HEATER WATER, OUTLET B
0​
87245-60340
Small heater hose clamps
6​
90467-21010
2​
87124-60070
No bottom line on that list, or $$$ column? safer not to know :rofl:
Getting ready for the full engine rebuild....and nope, still not wanting to add it all up.
This is more money in oem parts than I thought I would spend 10 years, but I did enjoy the research and hunt.
Nice list of parts, troubleshooting, and resolve. I am going through my rebuild right now and have my drivetrain out with my new short block on a stand getting ready to receive all the components. Mine blew a head gasket. New short block wasn’t necessary, but I had it there for my other cruiser so decided to use it and buy another short block later.
What shop is doing the work? Did you open up the box for the short block? When I opened mine up, it was contaminated with foreign debris. Looked like desiccant material had been crushed and exploded throughout my short block. It took me many hours of cleaning and blowing it out but the stuff was everywhere. Hope that isn’t the case for you.
Wow - thanks for the heads up on the dessicant FMC80. No, I have not opened it, the block is with the shop now, will keep an eye out for it. Sorry hear about your head gasket, but excited to hear about your build! Do you have a thread going on it? I agree, I might have been able to get away without a short block, but given the availability it seemed to make sense to hit everything I can while it is all out. I have a local shop doing the work, Aylestock Automotive. They have been a bit backed up, but Peter came with some strong recommendations and I look forward to seeing the work. Will keep the thread posted.
Right on, I look forward to your progress. My thread is here: Builds - 94 FZJ80 - Let the Adventure Ensue - https://forum.ih8mud.com/threads/94-fzj80-let-the-adventure-ensue.1240631/page-50
Nice! Congrats. Mine is coming out pan was full of metal. Ordered my short block today! Goodtimes lol
Oh no! Sorry to hear it Oneops, but congrats on the future new block and joy of a new build. Sounds like you traced some of the source of your sound then? I would be curious once torn down if there are any more clues as to what gave out.
Yeah I’ll know more when I get it torn down but it’s a spun rod bearing. Sadly.
While the engine build continues -- time to update this build thread with a number of the other updates.
First up - removed the old degraded aftermarket window tint using a hair dryer:
Rear speaker upgrade to the Pioneers recommended on this site:
I chose to keep the factory grills for the original look
...and while unnecessary, knowing that the original power antenna was broken, my daughter and I spend one Saturday afternoon fully replacing the factory power antenna. While re-threading the wire was a challenge, it was much easier as the dashboard was already off at the time.
