Broken rear sway bar bolts. How to address?
First time having a JDM was easier. The holes under the frame were threaded.
We offer SEXY Severe Duty Rear Adjustable Links with Nutsert option for the older side mount 80's.
Currently discounted
will these accomodate the whiteline sway bars?
The introduction of Whiteline and other HD swaybars is why our links were developed to meet the 104% percent increase. So to answer your question yes they will accommodate any HD swaybar. If you wheel hard and run HD swaybar you will want these.
@philip g - How were the bolts broken in the first place? I ask because I see that you are in CO. If you use you 80 for hard wheeling like rock crawling and these bolts broke due to sway bar impacts with hard earth, you might consider ditching the low hanging and vulnerable stock anti sway bar and install an AntiRock.
They commonly break when removing to install extended sway brackets
Not my experience but I’m on the west coast where cars don’t rust. Good luck.
