More of a generic issue, but would appreciate any advice. Recently made the beginner mistake of over tightening bolts which resulted in breaking off the bolt heads. I purchased a screw/extractor set and was able to extract one bolt, but really having a hard time with this one which is holding down the fuel pressure regulator.
Unfortunately, ended up off-centered due to the awkward angles due to engine. I'm trying to avoid ruining the threads in the fuel delivery rail. The bolt metal is very soft so I feel like it just keeps getting larger and not biting. If i were to drill deeper or go wider and just tap and rethread would there be any impact to fuel pressure or getting metal shavings into the fuel line? Last picture shows an approximation of how much of the 10mm bolt is stuck inside. Any other tips or advice appreciated!
