Broken front seat motor gearing
Atlanta
Anyone repaired the gearing on the front seat assembly lately? Both front seats are stuck, far enough back to drive but not all the way back.
When I attempt to move the seat forward or aft, one side begins to move but the other won't budge. The only way to move the seat is to electrically actuate so that one side moves 1/2-3/4 inch then crank the other side back with a wrench on the end of the gear shaft in the front of the seat. It's a tedious process.
What fix is available? If there is a part to install, what part is it?
Thanks
I had the exact same problem, it happend because the gearing mechanism was missing a threaded white plug. The member that was making and selling the replacement part was nakman and if you search under "white plug seat" you can also find more info on the problem. The part cost less that $10. Hope this helps.
That would be amazing if it fixes the problem. I found the white caps in the truck last year but didn't know what they were. Just had them stashed in the ash tray till I could figure it what they were for.
I'll reinstall them ASAP and see if it fixes it.
Thanks!!
