broken bolt need help
landcrusher909
Hobbyist
Southern Calif.
the head on the bolt holding the crosspin in the rear diff snapped off i was getting ready to install my aussie locker well now i am stuck and looking for ideas , this really bites!!!!!!!
Mace
rock scientist..
Staff member
s-Moderator
Las Vegas
Drill it out.
weld a nut on the bolt..
Pin_Head
OC, CA
It is pretty hard to get a drill on it w/o removing the carrier, especially if the bolt remians are recessed a couple of threads inside the hole. You might try tacking a short piece of 3/32" 7018 welding rod (1 sec at about 100 amps) onto the bolt remains and then using the rod as a handle to turn it out.
teapot
on the outside looking in
Good idea,I would have never thought of that. I would have taken out the carrier. Learn something new eveyday. thanks for the tip.
dgangle
total rice
Heart of Dixie
Usually when a bolt breaks it's because there was some big-time interference on the threads. This being the case you are really screwed. Easy-Outs are an oxy-moron. Break those off in a hole and the blue tipped wrench is your only hope. Good luck and let us know how you get it out.
Pin_Head
OC, CA
Sometimes the pin just breaks off with no threads left behind inside the hole. If this is the case, you can sometimes get the remains out with a magnet. Wiggle the center pin a little to help free it up.
Poser
Oh...Durka Durka Durka.
s-Moderator
Supporting Vendor
MN
Didn't he post up a while back that this was resolved....
He had two threads cookin' on this....
