Broken Axle hub bolt--safe to drive?
I just did my brakes and 5 wheel rotation. Drove around and 'seasoned' the brakes. When i got out to test tension with the 4 way, i broke a DS front axle hub bolt. I know i should replace them all, but how safe is it to drive with just 5? All of the others on the other 3 wheels are intact, but I get the feeling i should replace them all eventually when i replace the broken one.
Thanks!
5 out of 6 is probably not going to be an issue for around town til you can look after it. The question is why did it break? Was it because it was cross-threaded or did it seem to break on it's own? If it's the latter I would be suspect about the condition of ALL the studs on the truck.
this particular one was rusty, but i don't think it was cross-threaded. I suspect they all need replacement, and will when i can get a free weekend. Oh, btw C'dan, check your PM ;)
5 would provide plenty of frictional force for normal driving even at spec'd lug torque.
Heck, 3 would likely provide enough.
