- Joined
- May 29, 2008
- Threads
- 3
- Messages
- 10
It is more like renovation, as in I am gutting it like an old house...
So much that have to come out. Now I have 3 distributors, plus the original from the 67 engine that the previous owner mounted on it.
Radiator ( plus hoses, mount, cap), battery ( all cables, mount, everything), ignition (the 3 dist, not sure if any work, plus a whole tune up kit from CCOT . No idea what will work. Doesn't have an ignition key either), oil and oil filter ( the washable kind itself plus the mount and all the connections), gas pump, heater ( all hoses, the front unit, the inside unit, the back unit), gas lines, breaks ( all of it!)!!!!!! All of the above is what I need to work on just to get it running! I bought all the parts, so I just need to get to it! ( and miraculously learn how!!)
After all that is in I will start worrying about the exterior. It is rusty, but so freaking nice! My 76 is in perfect shape, but jealous, because I can only think about the 69 now. Will make it street, little army style rig, while the 76 is the big boy.
Today was great tomorrow will be crazy! I will start documenting this the same way I did with the 76, and post the pics.
Things like 4 small bottles of break fluid ( pints?) to then figure out next day that it all went down to the driveway, after running down the firewall ( lovely!). Then 2 days later I notice another big stain, left rear cylinders. SWEET!!! Today I found out that 2 new cylinders came with the car, so less to buy, more to put in. Still have to buy the master tho today Ive found out a Toyota cylinder kit came with it as well. Not sure I am that brave. Was brave enough to go to the yard where the old 69 engine was and take a lot of stuff from it. As much as was there, as the engine theoretically "came with the car".
The biggest challenge is that I don't know what goes where. The big old pink service book doesn't help much, as it is one generic book for all years ( not 67, of course) including several models ( FJ40, 55, 60, etc). So better then nothing but not good enough.
Again, the car is a 69, the previous owner put a 67 F on it, I guess his 69 went bad. Just that ALL on the 67 is different. Apparently it all changed in 68.
If someone here thinks this is impossible for someone without enough knowledge like me ( I do have guts tho. Lots of it!) please tell me now of forever hold your piece! (y)
To make it better, the gas pump was broken in the base, held in place by the gas lines, pretty much, and came out WITHOUT the arm that goes inside. The bolts for the base were loose, so I don't know if the previous owner had it out or if it is sitting at the bottom of the pan ( 98% chances that is where it is, I think...) so now can I even start the car ( if it ever does!) without removing the pan to fish the arm?
Tales of my 69!
Mauricio Feijo
PS: Will the intake manifold from the 69 fit my 76? They look the same, as opposed to the 67 that is completely different....
Tales of my 69!
Mauricio Feijo
