Two Buck
- Thread starter
- #21
In the 1st pic, look down the throat of the carb and press the plunger (Rubber accordian thing at 2 o'clock) and see if you get a squirt of gas - If you're not getting a squirt...
Ignition on as I do this? Or does it not matter?
2nd pic: Remove the nut (red circle or arrow) and (again, coil lead disconnected) crank the engine and see if gas is coming out of the fuel feed line. Should be a strong flow.
Another ignorance question: Where do I disco the coil lead?
3rd pic - what's under the nut -- look into it and see if there's **** on the screen.
Yeah, I've got the sight glass, I just can't tell if there's anything in there or not. It looks like maybe there is, but I'm expecting to see a line at the level of the surface of the pooled fuel. No line, so I'm assuming no fuel and that thinking I see some is just wishful thinking.
If gas is coming out feed tube, probably carb.
If no gas, look at fuel pump, filter - things between carb and gas tank.
Don't mean to be schmuck, , but you did put gas in the tank after you drained it...
LOL. I wish it was that simple. I put in about 2 gallons this morning (small gascan), then another 2 gallons this afternoon just in case the first 2 wasn't enough.
Thanks for the help, guys. I love the internet...
