break fluid leak at pressure switches
Discussion in '40- & 55-Series Tech' started by billdance, Jul 28, 2005.
  1. billdance
    billdance
    121
    May 15, 2005
    Tirana, Albania
    I kept seeing fluid down on my frame and tracked it down to my break cylinder...looks like it is comming out from around the pressure switch...the two nipple looking things below body under neath the reservoir..
    Are these switchs just screwed in...I dont want to start tighting on something that doesnt turn??
  2. dgangle
    dgangle total rice
    4,002
    20
    Nov 24, 2004
    Heart of Dixie
    Grab 'em with some small channel locks and tighten them a little. Or remove and put pugs in. They're just simple pipe threads.
  3. Pinion
    Pinion
    1,124
    1
    Jun 16, 2003
    Milford, Mass
    My brand new master cylinder leaks at where the brake lines go in, that big nut. I thought it was leaking through the pressure switches. Might want to give that a check as well.
