Thanks, I’ll check it out.Pretty sure it’s a smittybilt Smittybilt Defender
Thanks, I don’t have the time right now to remove the stock factory rack. So I’m looking for a Bolt on I know that mega warrior is probably a good one but I also think that Baja makes one. I understand the white limitations.The Defenders are rated for 150 pounds, evenly distributed, and a tire size limit of 33" or less. It looks good, but factor in the price of a mounting kit, and you're not far from a more capable product from Baja Rack like this: Baja Rack 80 Series Land Cruiser Standard Basket Rack
So I guess from looking at this picture that you can mount a Yakima basket to the rails on your 80 without removing the factory rack. Does that require non standard tower mounts?Thanks, I don’t have the time right now to remove the stock factory rack. So I’m looking for a Bolt on I know that mega warrior is probably a good one but I also think that Baja makes one. I understand the white limitations.
Herret
Thanks guys. Will the A1 mounts allow it to clear the roof rack?I don't know that I'd run 5 x A1 mounts, but I would run at least 3. And I agree about the factory rack--I wouldn't trust it after 20+ years either.
