brakes (1 Viewer)
Magnolia, TX
lately i have been having some problems with my brakes. They work fine except when sitting at a stop sign or something were i keep my foot on the brake for a awhile. They start off hard and slowly lose pressure till my foot is on the floor. Then i have to pump them back up to get them to be hard again.
I have been watching the fluid reservoir and the level hasn't changed in the last month.
brake booster ??
master cylinder??
kyle
Have you done anything to the brakes lately, that may have possibly introduced air into the system.
Grand Forks B.C.
Master cylinder, fluid is leaking past the pistons, you could change out the fluid and try to flush any crud in there out, but it's more than likly done.
goodtwin
Formerly CO. Now Seattle
x3 on the master cylinder. I repaced mine and it works fine. Mine was doing the same thing as yours.
Magnolia, TX
so where and what price should i be looking for on the master cylinder and how hard of a job is it to replace?
SoCal
x4 on the MC. I had this same problem. SOR has them for $150 (approx) thats where I got mine. Took about 30 minutes to take off and reinstall.
Pighead
Stop calling it an FJ
Camino
Y'know, back in the day, us old-timers would actually re-build our master cylinders...The dealership had really good re-build kits, heck, Napa had good rebuild kits and the rebuild itself was very easy. Might want to look into that.
BTW, agree it's your M/C...
Marietta, GA
It may very well be your mc but I had the same problem, bled mine and they work much better. Bleeding is obviously a cheap attempt at solving your problems.
Magnolia, TX
how much for a rebuild kit? it cant be any harder than the carb i rebuilt twice.
Vancouver BC
X 4? on M/C. I did mine a few weeks ago, it had the same symptoms although severe enough that there was no question it had to be changed . I also discovered that "aftermarket" Beck Arnsley cylinders are repackaged Aisins !!
Pighead
Camino
Much easier to rebuild than a carb, but buy a hone...your kit would be different than mine, won't tell you what I paid. Beck-Arnley makes re-build kits for Toyota masters too.
Grand Forks B.C.
Rip it apart and have a look at the bore before you buy a kit, if its to badly scored then just trash it and buy new.
