Brake Up Grade
Discussion in '80-Series Tech' started by SamB, Aug 11, 2005.
  1. SamB
    SamB
    70
    Jul 7, 2005
    Wellington, New Zealand
    Hi I've got a '92 HDJ81 that I want to upgrade the brakes on, I know that from some time in '92 80's got larger diameter discs and these are what I want to use.
    What I want to know is do the front calipers from a later model 80 bolt on to the earlier model 80 i.e is it the caliper that is different (apart from the obvious extra width for the thicker rotor) or is the caliper mount different and that is where the extra distance out from the hub comes from???
    Help!
    As an aside my current front rotors are only 20mm thick, I cannot find a reference to this thickness anywhere, they're all listed as either 25mm or 32mm??
    Sam :)
  2. bjowett
    bjowett
    3,767
    1,562
    Oct 28, 2002
    Western Massachusetts
    Just a guess... I'd say it is very probable that everything will bolt up... don't forget the splash shields on the back side.
  3. TX_TLC
    TX_TLC
    1,480
    9
    Apr 29, 2003
    Texas
    In the US the FJ80 (91 and 92) had 15" wheels...in '93 and on they have 16" wheels. I think this might correspond with a major change in the braking system.
    C-Dan can find out/would know for sure...
  4. jvoelcker
    jvoelcker
    127
    Aug 6, 2004
    Herefordshire, UK
    I think your rotors are below spec for your car. From memory the min thickness is about 22mm and yours have been skimmed/warn to the point where they are below spec. You will need to take them off to check against the min thickness figure cast onto the inside of the disk.
  5. IdahoDoug
    IdahoDoug
    8,864
    272
    Aug 9, 2003
    You don't need to take them off to measure them.
    DougM
  6. SamB
    SamB
    70
    Jul 7, 2005
    The discs went from 286 x 25mm to 311 x 32mm for '93 I'm hoping it was only the caliper that was changed and not the caliper mounting...
    Yes I'm thinking my discs must be really worn!!
