Maybe someone with experience with front axel rebuilds and brakes would know this:
I did the front axle and new 100 rotors and pads job. Bed-in the brakes and after 18 miles I've got one wheel with a tiny bit of play in it when off the ground. Is this okay? Should I tighten down the wheel bearing a little?
The other wheel doesn't have any play in it, but the new brake rotor is much hotter than the other side. Is this normal? Or is this a sign of a bearing too tight? Brakes too tight???
After four days on this I'm close, but since I need to use the vehicle this weekend for a trip I'm getting mighty worried.
(The reason I did the axle job is so I wouldn't need to worry about smoking a bearing on the trip!
