The 98-99 brake pressure switch is 2 wire and the 00-02 is 3 wires.
Working on a 98 that the ABS light has been on for months, brakes work fine but ABS does not. I bought a used skid control actuator but it is from a 00-02 and the pressure switch is different. Is there a way to use the 00-02 switch with the 98-99 wiring? I would like to keep the sensor hooked up if at all possible.
Also would it be safe to run it without the pressure sensor hooked up until I can get this figured out?
