- Thread starter
- #1
This started yesterday, go for the brakes and the pedal has resistance, then the bottom just drops out and the pedal needs pumped to get brake power back. Once pumped up the pedal is firm and holds pressure, but once in a while the pedal just goes soft and needs pumped. Is this a failing master cylinder? Brake booster? Check valve?
The brakes were flushed with fresh fluid and bled at the end of August, and had a very firm pedal up until yesterday when this started. Any help is appreciated!
