Brake Pad Life; Rear vs Front
My '02 LC has 49k and was purchased used with 20k in early '03. I have just replaced the rear pads with ~2 mm of pad material remaining while the fronts have nearly 8 mm of material remaining. What would cause the time-honored dictum of 2 sets of front pad replacements for every 1 set or rear pads to be upset? A mis udjusted proprotioning valve? Improper caliper carrier function?
Any experiences with you all that suggests a culprit?
I don't know what the proportion F/R of replacing pads on a 100 series but I have had other vehicles that went through the rear pads twice as fast as the fronts. It's not just about brake proportion, it's about how much pad material/surface area.
Perhaps the front pads were changed within the first 20k miles? Do you carry heavy loads all the time?
Oh yeah, and welcome :flipoff2:
I think it's just the 100's rear pads. A friend of mine replaced the rear pads in his '01 LC around 52K miles...they wore down to the screech warning material. He was suprised the rears wore out, as the fronts had lots of material remaining. In a past thread, IIRC, this was the consensus.
The rear pads on my 04 were just replaced and the fronts still have plenty left. I've had the car from new and never really to anythjing, just an 80 series once when he lost a front wheel.
Your problem is that it's a used vehicle and you don't know how it was driven. Could of had the fronts done at 20-30K miles and now at 49K the rears need to be replaced. On my 80 series I had to replace the fronts at 20K mile intervals and the rears at 50K mile interval. My "new to me" 100 series with 58K miles the rears look good for another 10K and the fronts look good for another 15K. But I don't know when they were changed?? I plan on changing both sets of mine when the rears need changing and then I will know for sure about wear patterns.
98LXand99LC said:
98LXand99LC, you need to read between the spelling mistakes, if you replace the word "to" with "tow" , it appears that he has only towed an 80 series once.
I just recently changed my front pads and noticed something strange. The front driver side inner pad was wore down to almost nothing. The outer pad and the passenger side pads were just fine. I am not sure if that has anything to do with the current alignment problem I am having.
Possible stuck piston(s) on your brake caliper. You'll have to inspect, rebuild or replace it. Yes, it can make your cruiser pull to one side.
The rear pads on my 98 LC went out first somewhere near 50k. Replaced the front pads sometime latter, not sure of the exact milage. I was surprised too as I had expected the fron pads to go first based on experience with other vehicles I have owned that had 4 wheel disk brakes.
I'll update this thread a bit. I just changed the pads on my one owner '06. It has 57.5K on the odometer. The rear pads were actually fine. They had about 50% of the pad still intact. For those who doubt the eyeballing estimates, I held up the new one to the old one and can tell you it was 50%.
THe front pads were worn considerably more, but still probably had 15% or so of their life left.
I don't drive aggresively, and I stop even less aggresively. Even so, seems to me that this is pretty good brake life.
to the OP's OQ... hand braking would do it. my GTi rears are gone with only 14k miles. the car was owned by a race company and "tracked" for the first 4k miles, so I assume they were feathering the hand brake quite a bit.
e-brake has its own brake shoes
Depending on driving habits, terrain and climate the front pads typically require replacement between 40 to 60k. Rear pads typically again depending on driving habits require replacement between 50 to 80k.
ALWAYS resurface front or rear rotors when installing new pads.
Glenn
Haven't confirmed this yet, but I just went to buy brake pads from Auto Zone and on their screen it stated that Ceramic were OEM for the front, but the dude stated "huh, ceramic weren't stock on the rear." Or at least his computer didn't state they were. So possibly the stock front was Ceramic and the stock rears were semi metallic?
If this is true, that could make a difference between front and rear wear. If the front was ceramic they would last longer than if they were semi metallic. Of course common sense would dictate the fronts having a shorter life than the rear, no matter the material.
