- Joined
- Aug 15, 2005
- Threads
- 776
- Messages
- 5,125
Brake system running fine until Friday. Parked it in my driveway and the parking brake was not on. Went to put my 1973 FJ40 into the garage and found out that my brakes were locked up. The brake peddle had a lot of pressure built up on it. (it was not pumped to build pressure, jsut stopped normally) I had to put it in 4 low and punch it to get it into the garage. It rolled better backwards than forwards. But the brakes were definitely keeping me from rolling.
Is this a problem with the booster or the master? (I sometimes hear a whistle from the engine after I turn it off, but I checked the vacuum line from manifold to the booster and it is a good solid connection).
Or could it be as simple as air in the lines? I also replaced the booster two months ago and it worked fine. No problems until Friday.
