brake lines and such
hi, guys. i'm tring to find what i will need to replace the brake lines on my 75 cruiser. does anyone know the size of the fittings, or will i have to replace them with ones from sor or something like that? i don't know if i can use simple compression fittings. does anyone know if this will work? if i have to, i will retap them to make something fitt. i don't care if it's a standard size. can compression fittings even be used, or are the fittings made just for the fittings built on the lines? anyone got any ideas?
Hard lines are avail from Toyota. Very cheap like $10 ea. You cannot make them for less. Even if you buy from SOR they are cheap. Soft lines are all avail from NAPA around $20 ea. I do not make lines, I buy them.
hard line fittings are all standard 10mm (inverted flare... the standard for older brake lines, rather than the newer bubble flare)... if you want to bend your own to fit just pick the lines up in lengths from ~6" to 60" at NAPA, brake part shops or the like.
jm
I just bent a hard line for the front brakes on my 40, it was pretty easy...give it a try.
Plus you get to buy tools ! :P
