Quick question: what's the size of the fittings that go into our master cylinders? I'm hoping to find a GM one that'll have the same size ports for when I do the hydroboost conversion.
Bret said:What are the chances of finding an adapter to run dash fittings instead? I found it a lot easier than flaring, bending, swearing, reflaring etc.
Bret said:I think they are 37' flare fittings. They should be the same style connectors you use on the jets. You sometimes see them as -3 or -4. Here is a picture of the adapter and the line. For more go to http://www.anplumbing.com/shop/
I haven't bough anything from them but it should give you an idea.
