Brake Light Switch
Tampa
My tail lights, light up fine - but only the driver's side brake light brightens when the brake pedal is depressed - the pax side is uneffected by the brake pedal. Does this indicate a bad brake light switch or faulty wiring/bad ground, etc??
Thanks
Poser
Oh...Durka Durka Durka.
Supporting Vendor
MN
are we working on a Lexus or a 40?
Tampa
Vitesse_6 thanks for the quick reply. I should have mentioned that I swapped in a known good bulb with the same result. I do have a meter - does each brake light have a seperate feed off the switch that ups the voltage when the switch is depressed?
Poser
Supporting Vendor
MN
Nomis said:
... well I finally found one, so this is definately on the 40. A '76 to be specific.
glad to see you updated your sig since last night... ;)
:beer:
Poser
Supporting Vendor
MN
I would get a test light, and connect it at the junction where the tail lamp attaches to the main harness, and see if you have power there...
I have seen quite a few of the connectors for the later style rear lamps cause issues with tail lamps...
Good luck!
-Steve
An alternate reality
Hopefully the original wiring hasn't been butchered by some DIY electrician installing a trailer light converter with wire nuts and Scotchloks.
Check the tail light connector for corrosion. I've seen OEM wire corrode and break where it’s soldered to the bulb base. The wire for the break lights could be broken there and the tail light would still work. The ground is probably OK if the backup, turn signal, and tail lights work but not the break light.
Get one of those handy test lights and make a break pedal prop so you can test the light housing and connectors with the break pedal pushed.
Good luck!
Tampa
Unfortunately, this is partly the case as I do see a trailer light converter set up zip tied to the frame. So I 'm guessing I should just rip out the trailer switch and go from there? The brake bulb itself does light up - just not the second, brighter filament when the brake is applied. I'll dig into this more when I get off work.
Tampa
Turned out to be a combination of the trailer wiring from the PO and some corrosion in the lamp sockets. I tore out the old trailer harness, soldered a few of the wires back together and cleaned up the corrosion. Now it's working like it should. I'll probably end up buying new tail lamp assemblies at some point.
