So my brake warning light comes on if the pedal is pressed in a sequence, rev the engine it goes off. I checked the vacuum seemed ok, replaced the master cylinder, same problem. I have bled the brakes a number of times (did have some air) same problem. I cant figure it out? The pedal goes stiff when the warning light comes on, I’m starting to suspect i may have a faulty booster. I've tried unplugging the switch from the reservoir (thinking its was a faulty switch) but the light still came on. Could it be the vacuum pump or vacuum storage tank? Can anyone offer some insight?
1985 - 3B BJ60
1985 - 3B BJ60
