brake fluid on firewall, clutch master cylinder
edmonton alberta
so it looks like my clutch cylinder might be ready to go. pedal engages closer to the floor. fluid doing a nice job of striping paint off the firewall...
anyone been through this?? can you get a seal kit for the master cylinder or is it a replacement issue?
thanks,
eric
the slave is 8 months old and the seals were rotted out... guess i already know how the story ends.
eric
i think it's funny how the things you want to do are interrupted by the things you need to do.
eric
Mine leaks a bit, any other options besides toyota?
THere are dozens of aftermarket MC for landcruisers but many are from the same factory.Try ebay. Ive been using aftermarket MC for years and no problems
i'm gonna call toyota tomorrow, i know that you get a seal kit for the slave, hopefully i can get one for the master as well.
i've seen big differences in quality between aftermarket and oem, and i don't mind to send a little more to have oem.
eric
eric
I know how you feel. I always think "Jeez, this part has lasted 20 years, I'd be happy to replace it with the same part" then I go to Toyota and realize that I could buy a parts truck for the same price as one part. I have thought about honing out OEM parts, then spoke to guys who have, only to have them tell me they had failures within the year. I priced out a new OEM master, I think it was around 400.00. I got a jobber for much less. I figure if the jobber last 5-10 yrs I'm doing OK. If you replace the master, the slave will fail shortly after. If you replace the slave, the master will fail shortly after. Go figure!
GG
