I know your subject line says help. What is your question?
Good idea, thank you.Well, taking a leap I would bet it's help resolving the brake fluid leak. OP, I'd suggest wiping things down so you can see new fluid more clearly and maybe have someone gently press the brakes to see if you can identify where the leak might be originating.
It could be from what is leaking, how to fix it, to best shop to fix this.Well, taking a leap I would bet it's help resolving the brake fluid leak.
