My master cylinder is shot, and I think it's leaking fluid into the booster. I'll know once I actually pull the master off, but if that is the case, would that render my booster kaput also or is it still serviceable?
they might have done fine with the clevis bottomed out on the pedal rod,
I don't think this adjustment affects the pushrod to master cylinder distance. (If this is wrong someone correct me). The clevis/pedal rod adjustment may need to be done after a brake booster swap for proper contact with the brake light switch.
