Brake Drum Screw??
Discussion in '40- & 55-Series Tech' started by Doug, Mar 12, 2004.
  1. Doug
    Doug
    6
    Mar 9, 2004
    Salt Lake City, UT
    Ok I finally got new rims and tires 8) 8) for my 40 after having to take the first batch back to Les Schwab because the tie rod ends rubbed on the wheels. :mad: :mad: But getting to my question there is a little screw on the outside of the brake drum that if I don't remove it the wheel sits off on the drum ??? ??? ??? ??? does anyone know what the screw does I can't find anything in the "Haynes Manual" about what it does.
    Any help or suggestions would be appreciated.
    Thanks,
    Doug
  2. Jesse
    Jesse
    25
    Oct 24, 2003
    If I am thinking right that screw is what keeps the drum centered.
    My FJ-40 did not have the screws when i got it, i never had any problems with-out them.
    I am not saying that you should remove them or anything, but maybe you could find a screw that fits in there flush with the drum.
    Jesse
  3. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    27
    Jan 3, 2003
    McCall, ID
    My '40 came with the screws removed, no doubt for the same reason you have encountered. As long as you have the drum on properly and then mount the wheel and tighten the lugs, the lugs will hold things together just fine. Generally, once it is on, the difficult issue is getting the drum off.
    I now have OEM rims, so I have the screws back in there. But it is more an issue of completeness than of need.
  4. fsusteve
    fsusteve
    3,802
    Media:
    18
    Albums:
    1
    49
    Aug 2, 2003
    Naples/Big Pine Key, Fl
    Jesse and Dave are right, that screw isn't an big issue, although it should fit flush normally. I wouldn't worry too much about it.
  5. Doug
    Doug
    6
    Mar 9, 2004
    Salt Lake City, UT
    :D :D THANKS FOR THE HELP GUYS. :D :D
  6. Landpimp
    Landpimp GOLD Star
    15,908
    Media:
    1
    1,943
    Mar 14, 2003
    Gig Harbor WA
    yep, screw the screw :D
  7. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,373
    Media:
    17
    Albums:
    1
    722
    Oct 1, 2003
    MN
    "does anyone know what the screw does I can't find anything in the "Haynes Manual" about what it does."
    Hard to believe...they are usually so consise and complete... :rolleyes:
    Your 40 looks really nice! :beer:
    Now fix your headlamp bezel... ;)
    Good luck!
    -Steve
