Replacing my 60's calipers, got it all ripped apart & cleaning up everything that's gonna get re-used. Finished up with the left side & when I started in on the right side, noticed right away that there is a bracket there that is not present on the left side! The bracket is held on by the bolt that holds the elbow on where the flex brake line transitions to the short hard line that runs to the caliper & the two caliper bolts go thru it before going thru the caliper "dog ears" (in other words it would be where washers would go on if there were any). Sorry for the horrible explanation. So am I correct in thinking there should have been one of these on the left hand side?. Anyone know what this bracket does anyhow, maybe lessen flexing on the short hardline?
Since I've had the truck since 2004 & things aren't all messed up w/this wheel, I'm supposing it's not a huge problem (or I'm very lucky?) My best guess is there was a bracket there, the PO had the truck serviced, they replaced calipers & forgot to put the left side one back on. Not sure why they'd even remove it though???
I know the bolt was not interfering with the rotor, but for now I will prob. test fit washers on the bolts to be safe until I can get one of these.
