while going to climb in i noticed that spring pin was wet... turned out to be brake fluid.
i think my brake booster is leaking, it started after i refilled the reservoir after taking the brake lines off for a SOA but i refilled it with DOT4. is there a big diff between DOT3 which was in it and DOT4 which is what i put in.( i thought DOT4 was just higher quality)would that cause it to leak? would air in the lines cause it to leak? or was it just weird timing that it started after i got down with the SOA? im gonna go and see if the brake line coming out of the master cylinder is loose, but i dont think that it is :-\...
thanks agian everyone
-al
-al
