HDJ100 1HD-FTE VX ex-UK
Sorry for the long thread but I'm pulling hair out and would hate to go bald over this. Here's the problem and also some background on my car and what we have done so far. Any and all ideas very welcome ! Thanks
Current problem:
- The Brake Booster motor (47070-60010) is overheating, due to the brake booster motor coming on (pumping) too often.
- The motor comes on even without the driver having pressed on the brakes.
- There are no errors appearing in vehicle diagnostics (Techstream).
- After some time, due to the Brake Booster motor overheating, the brakes will fail.
- There are No visible leaks on any brake lines! No ABS buzzer or ABS or parking warning lights.
Tools / Spare Parts used:
- All spare parts are genuine Toyota parts, purchased from one of the dealers of Al-Futtaim motors in Dubai, UAE
- Techstream has been used for Air bleeding and diagnosing errors.
How to reproduce the problem:
- Bleed the brake system with manual bleeding and air bleeding (front only)
- The vehicle behaves normally and brakes feel OK.
- Drive the vehicle for several hours in some traffic and also long distance (total driving time is approximately 3 hours)
- Brake booster still appears to behave normally. According to my observation, this "normal" behaviour means that the motor will come on either when:
- a) vehicle is stationary and brake is pressed 2 times
- b) vehicle is moving and brake is pressed 4-6 times
- Leave the car parked overnight.
- Drive the car again in some traffic the next day.
- Stop the car, check the brake booster. The motor is now coming on even without the driver having pressed the brake pedal. And the motor (and accumulator) are getting very, very hot.
How to get rid of the problem (temporarily):
- Brake booster behaves normally until you repeat the above steps to reproduce it (ie. drive the car for some time).
Background on the repairs which we have done so far:
- Brake warning lights ABS and Parking Brake and BUZZER came on and brakes lost functionality in July, 2015.
- Replaced Brake Master cylinder (47025-60022, only the master cylinder, not the complete unit) in October 2015.
- Brakes worked for a few weeks then ABS warning light coming on again
- Replaced Brake Booster w/Accumulator (47070-60010) in November, 2015.
- Brakes worked for a few days and problem started again. This was the first time when I paid attention and noticed that the Brake Booster Motor was getting very HOT. The Accumulator Assy is also getting hot, I assume due to heat conduction from the motor.
- After this, we have tried various replacement parts:-
- New complete front calipers (47730-60090, 47750-60090)
- Replaced all All 5 Flexible Hoses (90947-02A09, 90947-02A13, 90947-02A10, 90947-02A21, 90947-02A27)
- Replaced ABS ECU (89540-60070)
- Replaced Rear Brake Cylinder KIT (04479-60060)
- Even replaced the engine-side steel brake lines and joints, since we were fearing that air was getting in somewhere.
Other tests done:
- Car was parked, started engine from cold start and engine left running on idle.
- Immediately after switching ON, the Brake Booster pump was coming on (was pumping) for 7 seconds; and going off (stopped pumping) for 15 seconds
- After 1 hour of idling, the Brake Booster pump was coming on (was pumping) for 13 seconds; and going off (stopped pumping) for 8 seconds
- Car was switched off and parked for the night.
- The next morning, the Brake Booster pump is pumping for 11 seconds and going off for 7 seconds.
- Start the engine and drive the car, applying emergency brakes so as to trigger the ABS.
- Observe Brake Booster goes on LESS FREQUENTLY, going off for 45 seconds.
Current problem:
Other tests done:
