My 2000 lost it's power brakes while my 17 year old daughter was driving. After a $300 tow bill to get it home, I discovered a rusted ruptured line running along the driver's side frame to the rear. I cut out 18" of the rusted line and spliced in new line with double flares on the ends. The reservoir obviously was completely drained so I'm not sure whether I can get the system properly bled without the Techstream tool. I've been able to bleed the 2 fronts and the rear driver's, but can only get a dribble from the rear passenger caliper. When the key is on, the booster pump turns on every 6 seconds for about a second. Even when I pump the brakes with the key off 40 times to drain the accumulator, I still get the same behavior from the booster pump when the key is turned on- pumps for 1 second every 5-6 seconds. Does this sound like an additional issue with the booster pump? Should I have it towed to someone that can bleed it properly? Battery is completely charged. Thanks for any advice!
