Ok this problem has been bugging me for over a year now and it seems to have gotten worse, which is a HUGE saftey factor on a DD and trail truck.
First let me say what I've changed:
New booster - didn't help, took it back and currently I have a booster off a '94 and the rod is properly adjusted.
New master cylinder - about the 3rd one, they all have been rebuilt asin units from autozone. (which I've put on other cars and trucks with no issues)
LSPV off a '94 - IMO it was like new, super clean outside, and the fluid was nice and clean that came out and what was in the master cylinder.
Rebuilt the rear slave cylinders - adjusted and checked SEVERAL times over.
New front rotors
And a few years back I put calipers off a '87 on, before I had any types of problems.
NONE of this had helped and the problem seems to have just started out of nowhere about a year ago.
The system has been power bleed at 30psi OVER 10 TIMES!! I've probably pumped 5 gallons through the system by now, if not more.
The Problem:
Now the pedel will just go to the floor when depressed firmly. Under light force the pedel almost feels "normal" and the truck stops "OK" which IMO is about 40% of the brakes power. Under sudden braking, the pedel goes to the floor and the truck brakes at the same or less 40% force.
It's really bad when I'm 'wheeling and stoped on a steep incline, or decline. I've also had the brakes not hold when they are wet and I'm stoped, or should I try trying to keep stoped on a steep incline. It prettly much feels like a bleeder is cracked open but I have no leaks anywhere and have never lost any fluid.
This all leads me to belive that the brakes - front calipers, rear cylinders are not getting enough fluid pressure to lock up. However there is only 2 things that I can think of that can cause this - air in the system or a bad master cylinder.
THE PEDEL WILL NOT PUMP UP. Only when the truck is off will the pedel go to the floor and then pump up, which is what the booster is suppose to do.
SOMEONE HELP!! I can't take this crap anymore, its unsafe like crazy and I just got my lift on and want to drive it again.
New front rotors
The Problem:
