Brake Backing Plates
Point Judith Area, RI
I have a question....
I have a leaking brake line junction on the back of the caliper backing plate.
Is anyone here running a soft line directly from the axle hard line right to the caliper.
I need the truck to be up and running by Tuesday so I can get to a fisheries meeting....
I was figuring order the NAPA extended lines that I used after my OME lift.
I'd like to go SS, but the rubber lines only take a day to get to me.
Any thoughts?
jake
NLXTACY
Wits' End
Supporting Vendor
West Hills, CA
There is a kit you can get that eliminates that backing plate. Its a rock catcher that you don't want anyway from what I've read. I know for sure Mark's has them because I just ordered a set from him. Not sure who else has them. Maybe MAF?
downtime
What I'm thinking of doing is throwing the NAPA soft lines on there to minimize downtime - then put a Downey eliminator kit on there when I rebuild my knuckles.
Just trying to minimize downtime....
Wile E Coyote
Out in the streets, they call it murder!
Western AZ
NAPA hoses is what I used. I don't have the part #'s, but search user 'Kavik' 's post about his SOA project. On pg 2-3 or so, he gives part #'s. I used hoses that were 2" shorter than listed ( I'm thinking about 12 or 14") and they work just fine lock to lock and still enough slack.
slcfj62
In the valley of the Great Salt Lake.
Can you give me some more details on the kit that eliminates the backing plate? My drivers side backing plate scoop is broken and the cheapest replacement I have found is from cruiserparts.net and it is $75. I couldn't find anything like a backing plate on Marks Off Road (if that is the Mark you are referencing).
Thanks.
