Wanted brake and clutch master cylinder rubber caps (1 Viewer)
Tennessee
I'm in need of the brake and clutch rubber caps for a '76 FJ40. Mine are cracked a leak a little. Does anyone have a set of gently used ones that don't leak that they'll sell at a good price?
Thanks,
Mike
Thanks,
Mike
got you covered with both NOS and good used as well
pm sent
If your rubber caps are rotten it’s likely time to replace the brake and clutch master cylinders, check out Land Cruiser 40 and 55 Series for replacements.
This does not follow. I can think of several dozen times over the course of 30 years where I have put replacement caps on used masters that continued with many years of useful service. A couple of those have been on my own Cruisers.
The Elder Statesman is Absolutely Correct , REplacing a Master Cyl. Cap
Clutch or Brake , is a Normal Age & Time Interval Occurrence .
Lets all Remember & Recall , they Rot From the Outside inward , 9 times
out of 10 , this would imply a outside influence such as PCV gasses, CO,
NOX, maybe HC too ? certainly engine bay Temp. fluctuations , and Fluids
of various Kinds making contact to caps over a course of years , is common
place , i personally have NEVER seen one Rot or Crack from Inward to Out ?
BUT, ..............................
None Of this Really Matter's to a Level of Concern that Requires a
any further Relevant Debate any Longer Since :
VintageTeqParts.Com & Myself
WILL , BE Providing Fellow Member @Lifelong40Fan a Professional's
Sample's 3pc OEM TOYOTA Parts Reserviour Cap Kit with No Cost
Involved , including 2 Day Priority Mail Shipping to his Shop Door , & 1
Pint OEM TOYOTA DOT 3 Hydraulic Fluid . :D
Lets help Preserve both His Master's by Using Modern Materials &
Techniques with a Purist Based Mind-set approach ...........
PM sent ...........
Thanks,
Mike
I have some off my 78'. Let me know if you want some pictures.
I got my caps in the mail yesterday. Thanks Matt! Matt was super easy to work with and sent the caps and a few extra things right away! I highly recommend him!
