Greetings!
I have a 90 or 91 year box prado, well a friend does, and it seems as if the clutch has failed. While driving the car stopped...engine runs ,but there's no movement. Clutch pedal appears to work, as in the pedal moves, and with pedal movement the throwout arm in the side of the bell housing moves as well. There is no sound of clutch/flywheel engagement, and not even a twitch of movement with the driveshaft. It is a hydraulic clutch, and we did bleed the clutch line just to be sure that wasn't a problem (not that it should be, as air in the line would make it hard to change gears not stop all movement).
Anyway, any thoughts? Also, any tips on clutch replacement? Unfortunately, as is not uncommon here in Africa, we have no manuals for this vehicle.
Thanks!
JM
Thanks!
JM
