- Joined
- Mar 8, 2005
- Messages
- 95
My front suspension seems to be bottoming out. It's a two owner 2000 LC with 277k with me purchasing it at 48k miles in 2003. I've noticed this bottom out when going over bumps within the last 2 months or so. Evidence it's bottoming out is the clean spot on the lower A arm where the bump stop hits. This happens on both sides. New toyota shocks were installed a month ago, yet the truck keeps bottoming out. I've never touched a torsion bar adjustment so these are as they were from toyota. This is a stock ride height vehicle from what I can tell and I have 19.5" on the passenger side front and 20" on the driver side front (center of hub to bottom of the southeast add-on fender flare). Rears were an inch higher or so.
Torsion bar adjusters were about 9 threads on the passenger side, and 18 threads on the driver side. I would have thought they would have been the same?
I don't want to lift the vehicle as this is a mall cruiser. I think i'm due for a torsion bar replacement, but am unsure if an aftermarket bar would be doable on an otherwise stock LC. Could I increase the twist on these stock bars to increase the spring tension and eliminate the bottoming out without lifting the vehicle? Can I do an aftermarket bar at stock ride height?
Thanks for your thoughts, gang.
