Bottom End Bearings
Red Deer, Alberta
Which diesel engine if any, had bad bearings in the bottom end? Just wanted to know.
1HD-T. If you hop up a 1HZ (uses the same BEB's) my suggestion is to change them too. ACL bearings use a different composition, and many replace with them.
hth's
gb
Ok thanks. Where do you find the ACL bearing here in Canada? Would wayne have them?
I believe Radd has some, or as least has some coming in...
I don't know if Wayne has stock, but give him a call too...
gb
sorry,i do not stock them. give Rob or Steve a call...
i beleive they both stock the bearings...
cheers
Is it just crank bearings or the crank and connecting rod bearings? Is it a job that requires you to pull the engine or is it possible to pull the pan without pulling the engine?
