Booster or Diaphram (Brakes)?
Discussion in '80-Series Tech' started by Hltoppr, Mar 11, 2004.
  1. Hltoppr
    Hltoppr
    2,024
    Media:
    4
    Albums:
    2
    10
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    Hmm, hard brakes, very difficult to stop...
    MoGas and I have narrowed it down to the Booster or Vacuum diaphram.
    Pedal is hard, with a slight, "whoosh" sound when depressed.
    Any ideas?
    1992 FJ80
    3FE Powa....
    -H-
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Moderator
    22,265
    6,467
    Mar 27, 2003
    Land Cruiser Heritage Museum broom closet
    Yer booster is toast. :'(
    44610-60620 It's not cheap, but I do have one.
  3. Darwood
    Darwood
    1,957
    7
    Oct 8, 2003
    Z.O.W.I.E. Headquarters
    My Tacoma's brakes are like this. I also get a whoosh. I'm not entirely sure how to check if it's the booster or vacuum diaphram.
    I'd like to know a solution as well (even though it's not a cruiser). One of these weekends I'm planning on changing the fluid, resurfacing the rotors, and change the brake lines. I'm hoping this might help.
  4. Hltoppr
    Hltoppr
    2,024
    Media:
    4
    Albums:
    2
    10
    Aug 29, 2002
    Dan, how much food will your dogs get...be gentle. ;)
    -H-
  5. cruiserdan
    22,265
    6,467
    Mar 27, 2003
    yer gonna kill me.
    Wholesale is about 585 bucks :whoops:
    It lists at $780.48 :slap:
  6. Hltoppr
    Hltoppr
    2,024
    Media:
    4
    Albums:
    2
    10
    Aug 29, 2002
    So the "whoosh" I hear should be the vacuum seal breaking on the new bottle of KY... :doh: :'(
    -H-
  7. cruiserdan
    22,265
    6,467
    Mar 27, 2003
    Someone on he board recently found a good used one for a lot less. Sorry -H-, I take no pleasure from your problem. :-\
  8. Darwood
    Darwood
    1,957
    7
    Oct 8, 2003
    Actually what is a slight whoosh? I need to check the Tacoma to see if the sound is similar. I know one thing, with 33 inch tires in the Tacoma and the brakes feeling like they are lacking boost, it's interesting stopping.
    I also have brake lines in the front that need to be replaced, you see I tied the sway bar up since it was disconnected and wouldn't you know, it rubbed against the brake lines so now I can see the metal line under the plastic sheathing.
  9. Hltoppr
    Hltoppr
    2,024
    Media:
    4
    Albums:
    2
    10
    Aug 29, 2002
    Thanks Dan, you've got PM.
    Darwood,
    You'll know it when you feel it...It takes A LOT of pressure for me to stop at the moment. I'm keeping a good distance between other vehicles and have the lights on. Don't want to test the ARB on a Civic, don't ya know.
    -H-
  10. MoGas
    MoGas Central Scrutinizer SILVER Star
    2,035
    Media:
    7
    Albums:
    3
    48
    Jan 26, 2004
    Air Mobile
    [quote author=Hltoppr link=board=2;threadid=12956;start=msg119504#msg119504 date=1079039148]
    -H-
    [/quote]
    Do you get a complimentary reach around with that????
  11. MoGas
    2,035
    Media:
    7
    Albums:
    3
    48
    Jan 26, 2004
    Air Mobile
    Brakes, We don't need no stinkin' brakes!!!!!!!
    For that 1/2 block to your office???
  12. Darwood
    Darwood
    1,957
    7
    Oct 8, 2003
    Thanks H,
    My brakes aren't great but they aren't that bad. The brake booster does work since I've done a test on that, it just doesn't seem to work enough. I have very little pedal movement when I brake as well. My brakes will not lock up however.
    Also how's Flagstaff today? I love that town, I went to NAU for 6 years (with a year hiatus in between) and moved from there a little over a year ago to Northen Cali.
  13. Hltoppr
    Hltoppr
    2,024
    Media:
    4
    Albums:
    2
    10
    Aug 29, 2002
    [quote author=Darwood link=board=2;threadid=12956;start=msg119521#msg119521 date=1079040389]
    [/quote]
    Ha...I think BMT did that time, just without the hiatus.... ;) (Givin' ya crap, BMT...)
    Friggin' beautiful today! Trying to get Skeddy and GMEAMTN to go to Sedona tomorrow afternoon for some single track mtn. biking!
    -H-
  14. Hltoppr
    Hltoppr
    2,024
    Media:
    4
    Albums:
    2
    10
    Aug 29, 2002
    [quote author=MoGas link=board=2;threadid=12956;start=msg119517#msg119517 date=1079040115]
    [/quote]
    I will be at your place tonight....
    Yuck! :flipoff2:
    -H-
  15. landtank
    landtank SILVER Star
    19,227
    1,493
    Mar 27, 2003
    Groveland MA
    If your engine is idling fine then the diaphram in the booster is ok and it's a valve that is stuck closed that is the problem. The booster is made up of 2 chambers. There is a diaphram in the middle that devides those chambers. When you deprss the pedal the hole in the diaphram is closed and another one at the firewall is opened. Now the front chamber is in a vacuum state while the rear is at atmosphere so it helps pull the pedal down when braking. In your instance, the diaphram is closing but the rear valve is also staying closed so there is vacuum on both sides of the diaphram which holds it in a centered position. I've taken other manufaturers boosters apart, I'd suggest the same to you. They aren't really complicated and you could save yourself some cash.
  16. Hltoppr
    Hltoppr
    2,024
    Media:
    4
    Albums:
    2
    10
    Aug 29, 2002
    Thanks landtank,
    I found a used one at Cruiserparts for $150, so I'm just going to swap them out. I'll definitely look at the old one and see if I can fix it for a trail spare, though!
    :cheers:
    -H-
  17. Bradass80
    Bradass80
    220
    Jul 24, 2003
    Colorado
    Before you buy the bosster i'd put a gauge on the vacuum lines and check for a leak first, but it does sound like the booster, mine just went out too, real easy swap, also any year booster will work, Brad.
  18. DirtyLittleSecret
    DirtyLittleSecret
    1,398
    Sep 21, 2006
    WA
    What is it with the high prices? Schucks/Checker has em for about $280.
  19. Cruiser Jimmy
    Cruiser Jimmy Moderator
    2,041
    Media:
    100
    Albums:
    4
    509
    Sep 15, 2004
    Grand Junction, CO
    Same thing happened to me a while back.
    Got a '96 booster from a junkyard for about $150.
