I am working on a way to attach my roof rack to my roll bar. One way ,and this is where I need someone with more experience than I, is to bolt the carrier's feet direclty to the roll cage.
What type of metal weakness would occure if I drilled 2 1/4 holes lined up with the feet through the roll cage and use slightlly smaller than 1/4" bolts to secure the carrier? I would get some 1/4" tube and put that through the holea and weld them in place as a sleeve for the bolt and help keep some strength.
Is this a bad idea? I am asking here before I do it so don't flame too much.
I have a Yakamah type gutter mount cross bar set up I can also use. The other option would be to weld on some 1/4" angle iron the lenght of the cross bar gutter mount supports to the cage. The angle would work like the gutter mount on a the 40 and could try to attach cross bars this way.
I cannot simply set the carrier on top of the cage because the halo angles down towards the windshield and it gets to close to my head and I would forget it is there and knock myself sensless every time I got in or out.
