- Year
- 1994
- Vehicle Model
- 80 Series
- Location
- Boise, Idaho United States
- Mileage
- 198000
- Color
- rgb(255, 0, 0)
Mileage: 198,000
Factory triple locked
Non-USA center differential lock switch
Factory hand throttle, non-USA
Includes full set of grey leather second and third row seats, not currently in vehicle, all mounting hardware included.
Power sun roof
Wet Okole front seat covers. The original seats had sewing separation, which was repaired with a poor cosmetic result; hence the seat covers.
Factory hitch
Modifications:
ARB snorkel. Cyclonic air filter for dusty conditions included
Long block at 168,000 miles (thrown rod), installed by LTS Motors
OME suspension, heavy, 2” lift
ARB bull bar
Warn XD9000 winch, dyneema rope, Factor 55 thimble
4x4 Labs dual swing away rear bumper with tire carrier and 3 can gas carrier
Sliders, which include protection for cat converter (Rocky Road Outfitters) Vehicle can be lifted by the sliders
180 amp alternator
Axle, trans and trans case breather extensions
Trailer brake controller
Silicone hoses, including PHH
Rear heat delete
JVC single DIN am/fm/cassette with bluetooth
Antenna mast is broken
Locking center console box (Absolute Wit's End)
3/4” marine plywood load floor, carpeted, with aircraft tiedown tracks. Load floor mounted through factory seat bolt holes. All tracking is anchored by through-bolted t-nuts for strength.
Can store Pulaski, Handyman under the front of the floor in the back seat footwell.
Cargo box, 9-ply Baltic Birch, locks in/out, mounted to PS floor with turnbuckles.
Fridge and stove slide, 9-ply Baltic Birch. T-nut mounting to the load floor. Can be removed easily.
2 5-gallon water can holders mounted centerline behind front seats.
Recent work: Replaced vacuum booster, brake bleed.
Tires are Toyo A/T Open Country 10-ply, LT 285/75R16. Has been on a five-tire rotation since tires were new. Good tread.
Included: Spares, including u-joints, full tune-up set, original alternator, weatherstripping for DS front door; new 80-series OEM rear brake shoes, new 100-series OEM front brake shoes, various hoses and other parts.
Available: Pair of Yakima bars with awning mounts; Foxing 270 degree awning with two side panels. This is a whacking good accessory. Additional $500.00.
Have set of uprights for mounting a Front Runner rack on the vehicle. Price negotiable.
Specs:
Approach angle 34 degrees
Breakover 32.7 degrees
Departure angle: 34.2 degrees
Water Fording Depth: 26”
Ground clearance: 10.25” to pumpkin
Heavy duty front frame-mounted recovery points (Duzer). The ‘recovery’ points on the ARB bull bar are just for decoration; don’t use them.
Rear recovery points on 4x4Labs bumper
Power sun roof
Factory hitch
Modifications:
ARB bull bar
180 amp alternator
Rear heat delete
Specs:
