Body removal lift points (1 Viewer)
Buffalo, NY
I'm ready to lift the body off of the frame. My shop has a gantry with a hoist that I plan on using to safely and hopefully easily lift the body from the frame and place on a don't I made
My question is where would be the best places to attach chains/straps to the body to lift it?
Would the front door and lift gate strikers be able to handle the weight of the body? I would ideally want 4 points to lift the body from. Open to suggestions!
thanks,
Lukas
here is a creative way to do it:
BC runners just added a video where they lift a chinook body off using the door flanges
A common way to do it for 60's is to use an engine hoist with chains and d-rings bolted to the seatbelt mounting holes in the floor. The boom of the engine hoist going through one of the door openings.
Since you have a gantry, you could possibly bolt to the door hinge locations like the above video on either side with straps to balance the load front and back. I would definitely *not* lift with a rope or chain around the roof.
someone on here used a gantry or similar and put boards/beams through the front and rear doors openings. Then lifted the beams.
Tho, I would be very cautious with this approach as I wouldn't want the body to bend where the beams contacted it.
You can bolt to the front door and tailgate hinge bolt holes, but then it seems your chain/strap would be wrapping around the body.
Yes that is what I'm planning! Thanks
Yes I was thinking the same thanks!
Got the body off this weekend. A few hiccups and bent lines but overall went pretty smoothly and I was able to just hook the straps to the door and tailgate hinges. Doesn't appear to be any bending or deflection.
Hello,
Is there any information on the Forum in the way of a checklist of what to disconnect in order to remove the body? Right now I'm just going through it with common sense.
Hello,
Common sense and slow speed are a good place to start. Do you have the FSM?
