Body mount Torque Specs (7 Viewers)
Anyone know the torque specs of the cab mount torque specs?
Check the FSM it's not in there
I’ll check my manual in a few minutes but I don’t think it’s very high. I seem to recal abandoning those specs and tightening them down until the bottom bush started to flare and then backed off a half turn and then locked the nut down with the second nylon locking nut. I installed 4crawler’s poly body mount kit and the hardware is a bit different than the OEM.
I have the big repair manual from Toyota and I don’t see anything about replacing body mounts in this book. I did take these pictures for you. Maybe they’ll help you out. But I think, if you use loc-tite or two nylon nuts and you tighten it untill the rubber begins to flare you should be good to go. Thy don’t need to be very tight. You don’t want to crush the rubber.
really ***ing snug. clamp it down, don't go full-robotronic, but put some ass on it. but do try to not crush the poly bushing. okay
