Body lift....
Discussion in '40- & 55-Series Tech' started by Hossdog, Jul 19, 2005.
  1. Hossdog
    Hossdog
    175
    1
    Apr 2, 2005
    Hollister, CA
    Lookin for a GOOD QUALITY 1" - 1 1/2" body lift any suggestions? Saw one on Man-a-fre I believe and it was black anodized aluminum....seemed nice. Just pickin the big brains in the forum! Thanks
  2. andrewfarmer
    andrewfarmer
    799
    1
    Jul 18, 2005
    Wellington, NZ
    Make one - just get some pucks turned up somewhere and buy some long bolts.
    I used UHMW plastic, some prefer aluminium.
    Can also use skateboard wheels (no not kidding!).
  3. Delboy
    Delboy
    3
    May 11, 2005
    Kilkenny, Ireland
    Check out this site. http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml He makes body lifts for a few different types of 4x4. Well known on the 4runner sites. I got a 1" lift for my Hilux Surf from him. Top quality and reasonably priced. Very helpful guy also, so if he doesnt do Cruiser lifts yet, he will if you ask him and give him some info.
    Also, Hello fromthe Newbie. Great Site! :cheers:
  4. Ultima RB
    Ultima RB
    57
    Aug 4, 2004
    NSW, Australia
    With a 1" lift, did you have any trouble with brake/clutch lines lining up again? Or any other hassles?
  5. wngrog
    wngrog SILVER Star
    29,403
    33,813
    Feb 10, 2002
    Canton, Mississippi
    I got my body lift from Man-a-Fre Very nice quality.
  6. Delboy
    Delboy
    3
    May 11, 2005
    Kilkenny, Ireland
    No Problem on the Surf cause all the lines are coiled which allows for a lot of movement without having to be adjusted.
  7. lone gunman
    lone gunman
    1,400
    15
    Aug 17, 2003
    granite falls WA.
    do a search, i have posted up a few times on it. i did a 2 in. body lift and i posted a link to cheap pucks. no problems with lines or wires, i think i had like 30.00 or 40.00 bucks into mine. good luck.
  8. petescoffee
    petescoffee
    1,918
    70
    Dec 29, 2002
    Walnut Creek, CA
    I've seen a few trucks with the MAF and it looks well done.
    I have also seen a couple of trucks done using the rollers from a boat trailer cut to thickness. It looked a little hokey but it works.
  9. snailwagon
    snailwagon
    1,042
    4
    Jun 11, 2004
    high desert, ca
    You are better off hitting up Roger at 4crawler , very good customer service, and a fellow toyota freak.
  10. Macgyver5
    Macgyver5
    206
    Feb 3, 2005
  11. camcruiser13
    camcruiser13
    6,978
    Media:
    3
    Albums:
    1
    29
    Jun 22, 2004
    sittin on the couch in UT
    hockey pucks will break, dont use them
  12. Hossdog
    Hossdog
    175
    1
    Apr 2, 2005
    Hollister, CA
    With the Man-A-Fre lift did you still use the OE style bushings? Ive got the kit from Energy Suspension sittin in the box right now.
  13. andrewfarmer
    andrewfarmer
    799
    1
    Jul 18, 2005
    Wellington, NZ
    Only hassle (if still std steering) is the steering column - I had to modify the fitting where it goes through the firewall.
    Shouldn't be an issue if you've had p/s fitted.
    And the wires to temp and oilp senders were too short - had to extend them.
  14. LC_Hamma
    LC_Hamma The Anti-Leafer
    2,675
    25
    Nov 11, 2002
    Dallas, Georgia
    That's what I used. It helps to know someone who has access to a mill & works with UHMW on occassion:
  15. FoYoChe
    FoYoChe
    176
    Apr 4, 2005
    Northwest
    That's Nylatron. not uhmw
  16. kenai
    kenai
    248
    Aug 14, 2005
    what about the front fenders? Since they are bolted to the frame?
  17. JGM
    JGM
    151
    Aug 30, 2005
    Scottsdale, AZ
    Another vote for Roger. :D I have used a bunch of his stuff on my4R. Great guy to work with.
  18. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,429
    Media:
    17
    Albums:
    1
    875
    Oct 1, 2003
    MN
    How tall of a lift are you looking at installing?
    You can either drill new holes in the brace, or if you go three inches, you only get two bolts in the support to the frame, unless you lengthen the fender support.
    :beer:
