Body and paint gray 62 (1 Viewer)
Almost ready to roll this one in the booth. Going over it for the final time, I’m finding rock chips everywhere. A good handful of them have rust developing but you can’t see it until it’s sanded down. I’m grinding the little rust spots down with a Dremel Tool, then fill with fiberglass filler. Next, epoxy prime the bare metal then high build 2k primer, sand then done. These chips really slowed me down today, but glad I found them now.
Rear wiper nut was rusted and couldn’t remove it. There was a little bit of rust showing underneath it. I had to cut the sleeve and nut off to access the rust. Most of the rust sanded off with 220 grit, then I soaked a rag with rust dissolver and let it sit for 30 min. Sand, epoxy prime, 2k prime then done.
Kelly, one of these works great on those little rocks chips, you can avoid a little step also, mini sand spot blaster..
Again,great work buddy.. :cheers:
That little blaster is nice. I want to get a small one like that, it would be convenient. I have been using my pressure tank blaster for lots of stuff. Thanks!
What paint and clear do you like? I used ppg base and ppg 2002 clear, I’m in love with the clear, It looks wet With a good buffing
I have been using PPG.
In the booth tonight with doors and hatch. Tomorrow night I will drive the vehicle in the booth and paint it. It’s 100 degrees during the day, so I have to wait until it cools off to 70 at about 9ish. Just got home at 1am.
The vehicle went into the booth, prepped, and cleaned 3 times. Mission abort! Bugs everywhere in the paint booth. I will try to find out how they are getting in and seal it up tomorrow. :mad::mad::mad::mad:
