This is one of the rod journals in the 3B that I put in the FJ45LV. This is a Japanese takeout from I believe a Dyna truck or Coaster bus (it did not have a 'Cruiser tranny when I got it). It is the rotary injection pump version of the 3B. I was pulling the pan off to swap it with one which I had an oil return bung welded/brazed on to return oil from the Supra turbo that I have also installed.
Would you plastigage the bearing to see how it is or is it even a bearing issue?
Why only on one side of the rod journal and not the other?
Any ideas of cause? Is corrective action needed? If so what?
