Has your heater blower lost the "low" fan speed setting?
If so, you probably need to replace your blower motor resistor. Here is what I used to replace mine. It is a Vishay/Dale Wirewound Power Resistor part# HL-50-06Z 1 OHM 5% 50W
You can purchase it here for $3.38. They also sell mounting brackets or you can make your own. http://www.mouser.com/catalog/626/500.pdf#search='dale%20hl5006z'
Mouser part# 71-HL50-06z-Value 1.0 - 1.0k
Note, this part is longer than the stock resistor and you will need to mount it to the top of the blower motor. My install is not the most elegant as you can see from the picture below but it does work.
