Searched the archives but no help.
I have a 88 fj62 and the heater-A/C blower motor no longer works on the 2 low speeds. It DOES work on the 2 higher speeds. I know the blower motor was going out. The brushes were about worn to nothing so I just installed a new motor hoping it would also fix the "missing speeds" problem too but it didn't. I'm looking in the factory manual (which isn't much help) and I'm guessing the problem is the blower resistor. However, I can't find it as a part for the fj62 on www.sor.com, in fact, they don't even list a resistor for the fj60/62 anywhere that I can find. Anyone trace one down and know where it's mounted on the vehicle? Hopefully its not part of the switch assembly which likely cost more than just a resistor.
BTW, I have about 0.3 volts at the motor when the switch is on the 2 lower speeds and 12v+ when its on the 2 higher speeds.
