Black rubber antenna where (2 Viewers)
Where do I get a black rubber antenna to replace stock one.I need one that will use stok antenna wire and sit on fender correctly(angled grommet)
Any universal rubber antenna will work, just find one that is adjustable. As for using the stock cable you'll either have to cut and solder or use the old one as pull feed for the new one, or run the new in parallel (to my limited knowledge).
Got mine from Pep Boys, $16.00 works great.:cheers:
